Hi guys.I'm having a problem with my Nero Vision Express.I have a dvd writer and I used to use Nero vision express to burn my dvds.there was no problem at all in the beginning.I would add the xvid file and Nero would automatically convert it and burn it as a dvd.And recently i have no idea what happend but when i try to burn the project the program starts the time but it doesn't respond.And then after couple of hours it burns the porject half way.every time i treid the same thing happend.I tried roxio dvd builder but it needs diffrent format of file etc.I have uninstalled the program but it didn't help.can you guys recommend me a software that will work as simple as nero express?thanks in advance
Were you using the latest version of Nero Vision? If so, and it didnt work, did you try an older veriosn to see if maybe there are problems with the current version?
Yeah the latest one is 6.6 and i have it.The oldest Nero which is 5.9 something doesn't have the nero express.is there any other software similar to this one ?Originally Posted by D.A.R.J.R.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
