I have a problem of the moving objects (not smooth object's moving) on MPEG-2 converted from DV-AVI with TMPGEnc. A still pictures looking fine, while a moving objects or when shoot horizontal footage appearances with jerks and flickering. Does somebody now how to prevent this phenomenon?
I use bottom field first for DV and 25fps for PAL. Video mode: Interlaced.
Please help.
Thanks in advance.
YR
Increase the bitrate, use VBR 2pass, set DC component precision to 10.
Cheers, Jim
My DVDLab Guides -
Thank you, reboot
I've already made meny trials with VBR 2pass, 5000 to 8500 kbps, interlaced/progressive but CD was 9. Now tried CD=10. Without improvement. Objects moving horizontally steel blinking. I paid attention a regular TV broadcasting do it too, but much less.
VBR or CBR or high/low bitrate don't influence the problem. Any suggestions?
YR -
Try changing your field patterns.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Are you viewing it on the PC or on a TV?
PC's don't do interlaced well.
On a TV, it may look perfect.
Have you checked the source to see if it's jerky at all?Cheers, Jim
My DVDLab Guides -
Yes, now I know what was a problem. Encoded with a progressive mode video caused this blinking. I tried interlaced mode - a result is no jerky. But generally a picture is not looking so clear as progressive.
Please advice how to improve (to clear) an interlaced picture.
Thanks in advance.
YR
Random Video Jerks on Input Source to Viewcast Osprey 240e
By nephesh in forum Video Streaming DownloadingReplies: 1Last Post: 24th Feb 2011, 10:14 -
flickering border
By stompinne in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2009, 13:34 -
Menu flickering
By mrcoolekin in forum Authoring (DVD)Replies: 7Last Post: 14th Mar 2009, 13:01 -
Flickering
By artistguy68 in forum ffmpegX general discussionReplies: 0Last Post: 10th Mar 2008, 22:01 -
Flickering of DVD
By markannab in forum Authoring (DVD)Replies: 2Last Post: 30th May 2007, 19:01
