I want to make a video divided into chapters(after editing it), then burn it to a VCD
You would typically do this in the authoring process to make the VCD.
The "how" of this depends on the program you're using to author the VCD.
calculus -
Premiere Pro isn't a DVD authoring program. It will only generate a preview DVD of the MPeg timeline.
just import your movie in and use the Razor Tool to cut the video in three parts, then export each part individually. Then you can use the three clips as chapters, this way is good because you get to pick where you want to stop/start each chapter, go ahead and make some frame shots to.
How to make chapters with a mkv file?
By neworldman in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 17:18 -
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 12:05 -
how to make 3 vob files into a DVD with chapters
By c1steady in forum Authoring (DVD)Replies: 8Last Post: 3rd Oct 2009, 05:46 -
FAVC - How to make chapters instead of titles ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2008, 13:03 -
How to make 'chapters' on an audio CD
By UmmAddan in forum Newbie / General discussionsReplies: 15Last Post: 4th Jun 2007, 03:08
