I've been looking at clips for the new XBox and the vids play within IE WMP but are stired in the temporary internet files folder as DAT files.
I've tried pretty much every tool I have and also tried suggestions here to burn with Nero to VCD or use Isobuster to extract an mpeg. Nothing gives....
How do I convert these to avi or mpeg?
Regards,
Rob -
Tried that:
'Could not locate MPEG stream'
Here are some of the files (try from the top down as I'm still uploading):
DAT folderRegards,
Rob -
They're not true .dat files.
What site?Cheers, Jim
My DVDLab Guides -
They're WMVs.
Right-click the video window (within the browser), choose properties and copy the URL (Location
and paste into browser address bar.
Download the .ASX and open it in a text editor. Copy the URL (in the case of the link you provided, it's mms://wm.microsoft.com/ms/xbox/video/forza/Forza-e32004-001-Hi.wmv) and use whatever you want to download. IE has a problem downloading MMS streams so use a download manager of your choice. Using FlashGet and that particular file you will end up with a 10.8MB WMV called 'Forza-e32004-001-Hi.wmv'. -
I use NetTransport, and it works well for mms:// links.
Cheers, Jim
My DVDLab Guides
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
.Dat File?
By niteghost in forum Video ConversionReplies: 3Last Post: 24th May 2009, 21:38 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
