Hello,
I have a big problem... when I'm authoring 2 vob-clips in the same VTS with TMPG DVD Author, there is a nasty break (nearly the same as a layer break) between the 2 clips on my Sony DVD-Player (played on the PC there isn't any). Is there any chance of authoring this DVD without seeing the break?
That's the problem.Originally Posted by reboot
I think i gotta explain the whole thing...
I'm trying to get my whole VHS Archive on DVD with using a standalone DVD Player. But on some VHS-Tapes the pictures falls out for 2-3 seconds. When I author these VOB-Streams on TMPG DVD Author, the audio gets out of sync at the point at the broken frames. The only thing is cut the Vobs in two parts and rejoin as two clips in the same VTS, but there is the problem I've tried to explain.
Can somebody help me? -
Cut, fix, rejoin.
You shouldn't be editing .vob's anyhow, you should be editing mpegs.
Womble mpeg wizard would be ideal for this.
I think it may even take vobs...Cheers, Jim
My DVDLab Guides -
yep try mpeg video wizard or maybe mpeg-vcr is enough or videoredo. (freeee trials available)
Multiple clips form a single video file
By ripper316 in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2011, 13:52 -
Joining Mixed Multi Angle Into Single VTS
By werdna1900 in forum Authoring (DVD)Replies: 1Last Post: 13th Jun 2009, 05:26 -
Multiple home video clips... One giant AVI->MPEG encode or break it up?
By binister in forum Video ConversionReplies: 1Last Post: 14th May 2008, 14:59 -
Select Layer Break In Authoring App?
By RABinMS in forum Authoring (DVD)Replies: 6Last Post: 21st Nov 2007, 09:36 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 11:48
