I am encoding movs with ffmpeg, and I can't seem to get it to produce anything that isn't either 16:9 or 4:3. I am cropping the sides quite a lot - 48 pixels on each from the original mpeg2 transport stream, which produces something a bit non-standard, closest to 3:2. If I set 16:9 in the video parameter autosize, it will stretch the image to fit. If I set anything else, incuding 3:2 or unconstrained, it jumps to 4:3 using the height as the base setting and ignoring the width.
Suggestions, please?
Results 1 to 1 of 1
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 04:10 -
ffmpeg automatic scaling possible?
By richiedood in forum Video ConversionReplies: 14Last Post: 2nd Jul 2011, 08:52 -
the effect of scaling to frame size (PP)
By metathran in forum EditingReplies: 4Last Post: 18th Feb 2010, 13:59 -
PowerDVD: HD Scaling problem
By Kim Jespersen in forum Software PlayingReplies: 5Last Post: 10th Apr 2009, 05:44 -
DVD Up scaling/up conversion
By Oakman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Jul 2007, 22:25
