Hi,
which tool should I use to convert dvd subtitls (IFO - VOB) into IDX / SUB???
MIllan
Install VobSub (freeware), go in the Program Files\Gabest\VobSub and open VobSub Configure.lnk
A window will pop up. You chose open and select "Ifo and Vobs, for creating idx/sub (*.ifo)". You open the VIDEO_TS folder of the DVD you want to rip subtitles from and then you get a window in which you have the option to chose which subtitles the idx/sub will contain and which it will not -
I tried your solution , but could find no "configure.lnk" option. I see other configure options, but no "configure.lnk> Using version 2.23???
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 22:22 -
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 05:23 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10 -
To many IDX & SUB subtitles from DVD...
By locousa in forum SubtitleReplies: 8Last Post: 11th Aug 2008, 09:02 -
Question how to time idx/sub files and use them (with avi) to make DVD
By jimdagys in forum SubtitleReplies: 11Last Post: 15th May 2008, 20:35
