    Jan 2005
    Kenosha, Wisconsin
    I am having a hard time using the dvd decrypter. After shrinking the dvd with DVD Shrink (which is an awesome program), DVD Decrypter starts to write the disc but stops shortly afterwards. I have burned enough coasters, so I figured that it was time to seek some help. I hate using Nero, is there any other way that I can fix this problem? Clone DVD/Any DVD does the same thing.
    Dec 2003
    Does it give you an error when it stops burning? It so, please tell us what that is. We need a little more info to try and help you out with this.
    Mako
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Does Nero work properly ?
    If in doubt, Google it.
  4. that might be the speed increase crash.
    it may be media or pc linked,as the problem is dvd decrypter starts writing slowly,then pauses,then speeds up,and sometimes,either the pc,or the media cant keep up and itll crash.
    MORE INFO please.
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
    Sep 2003
    Can you fill in the rest of you computer profile. It might be that you don't have enough free space on your HD when you start to burn.
