on the menu creation guide for nero 5.5+, there is an instruction like:
Important! To be able fast forward/rewind the SVCD on your standalone DVD-Player you must:
Download this scandata.dat (right click on the link and select Save Target as to download it, it is just a very small textfile).
Then add/drag the scandata.dat to the EXT folder of the SVCD.
i don't quite understand the point of the scandata.dat. i checked my SVCD discs and they don't have scandata.dat on them, and i've been able to fastforward/rewind with them....can someone elaborate?
You dvdplayer might be able to FF/RW svcd without scandata.dat but some don't. Mine (APEX) doesn't do the trick without scandata.dat. Anyway this is not an issue anymore after using VCDImager.
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24 -
Need a Guide/Tutorial for Sonic Scenarist and Menu creation with Photoshop
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2007, 04:04 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49
