Yea anyways... it takes me about an hour and 10 mins to encode a video clip that is 20 mins long or 350mb. I know my friends computer which is pretty fast takes about 20-30 mins. I dont have the money to really build a new computer. So what kind of hardware determines how fast it encodes? I have a athlon 1.10 ghz processor and 768mb of ram and a Radeon 9700 Pro if it matters. Any ideas? Thanks i advance
Results 1 to 16 of 16
The processor is the area you need improvement in. You'd be better off building a new system rather than trying to simply upgrade your processor, as your current Motherboard won't be able to utilize the newer, faster processors.
I know you said you can't really afford a new computer, but I've built a pretty good system for about $150. Fry's/Outpost.com, for example, sometimes have Sempron/MB combos for around $50-70. I've gotten a Sempron 2500/MB combo for $60, it would cut your processing time about in half. Find a cheap tower or use the one you have now, use the HD, and use your video card. You'll probably need different RAM but you can get 512mb for about $40. So for about $100 or so you could put together a pretty decent system (if you use your existing Video Card and Hard Drive(s)). -
For "realtime" encoding, I'd suppose ~2.5 - 3 GHz will do. I get 0.5 - 0.75 on my 3.2 GHz box (20 min video done in 10-15 min with MainConcept)
My view on processor pricing is that the fastest is always too expensive, but that the second fastest model has dropped radically. The drop to even lesser processors isn't that big.
/Mats -
Yes, MainConcept is faster than TMPGEnc.
/Mats -
Originally Posted by mats.hogberg
Xactly. And if 200 MHz (like 6%) speed difference makes 100% price difference, the decision isn't that hard.
/Mats -
Originally Posted by cw_ek9
/Mats -
For the same encoder, encoding times scale fairly linearly with CPU speed so long as minimal RAM is present (say 256-512MB). Typical graphics cards have minimal effect.
Some higher end encoders like the Mainconcept versions in Premiere and Vegas support Intel's Hyperthreading. Hyperthreading will give an additional 10-20% encoding speed boost if supported by the encoder software.
See encoder benchmarks for more:
http://www.digit-life.com/articles2/intelamdcpuroundupvideo/ -
That difference ammount in speed does NOT justify at all the difference in the price.1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
when I use TMPGEnc, it takes about 3 to 3 and half hours to convert a 20 min avi to m2v/wav
but, I'm having some issues right now and am currently unable to run my CPU at it's full speed - when's the last time you heard of somebody underclocking their PC :P ?
before my problems, it was taking just under 2 hours
additionally, the settings you choose will also increase/decrease the total dealing time"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Please update me on sw :-)
By boeniz in forum DVD RippingReplies: 7Last Post: 13th Apr 2011, 08:15 -
Windows Update?
By videobread in forum ComputerReplies: 1Last Post: 12th Jul 2007, 12:27 -
Cannot Update my SVCD2DVD!!
By rodawg71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jun 2007, 01:50
