Can I use any encoder programs from tmpgenc to use with DVD Rebuilder instead of CCE?
Thanks.
You do have to edit the Rebuilder.ini to get it to work
Well if he doesn't want to pay for the Pro version and wants the free version, then he'll have to edit the REbuilder.ini file and change the line that points to the QuEnc.exe to the HC_Batch.exe (then use QuEnc mode). It also needs an HC.ini file in the same folder as the HC_Batch.exe like this:
*maxbitrate 8000
*matrix qlb
*profile best
*logfile C:\Program Files\DVD-RB\HC\test.log -
Yes, otherwise you do it manually.
Does dvdrebuilder use multi cores?
By the_man_one in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2010, 00:25 -
DVDRebuilder Free/Pro 16:9 crop question
By ecc in forum DVD RippingReplies: 5Last Post: 29th Apr 2009, 11:05 -
No audio tracks (DVDRebuilder)
By stiltman in forum DVD RippingReplies: 3Last Post: 11th Nov 2008, 22:45 -
DVDRebuilder
By santino_avi in forum DVD RippingReplies: 5Last Post: 20th Jan 2008, 15:03 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 21:00
