  1. Anybody here used the Nero SDK to write a video DVD? The DVDs I get out of it work on my PC, but not on my home DVD player. However using Nero with the same batch of disks does work.
  2. I only use Nerocmd, works without a problem for me (does not create the AUDIO_TS folder, but that's already discussed)...
    Are you referring to nerocmd the com interface or another part of the SDK?
  3. Don't think it's a com interface as it comes with a library, not sure exactly as I didn't write it (just have to fix it ).
    Solved the problems anyway. One is that you have to have version 6 of Nero to make DVD video work through the SDK, and the other was that I wasn't setting the UDF flag.
