I thought an .mpeg file was suppose to be a compressed file of an .avi? So how come when I convert it it's almost 100mbs bigger? I had to encode the audio seperately [with Virtual Dub] then I combined that audio file with the video file in TMPGEnc. Please help.
AVI in itself does not mean anything. It can be compressed or uncompressed, and when compressed all depends on the codec that has been used. In your case, the codec was probably a DIVX codec, which compresses video further than MPEG1. Recompressing to MPEG1 will therefore produce a bigger file.
If you want to experiment, open with Virtual Dub and output to uncompressed video, you ll see the size of the resulting AVI...
editing or converting 24fps mpg and retain original length and playback
By MisterRPH in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2011, 22:36 -
Help Converting VOB File to MKV (including original AC3 and Subtitles)
By CCS4George in forum Video ConversionReplies: 1Last Post: 10th Sep 2010, 17:53 -
After converting HD video files for play on XBOX360, should I keep original
By ryangarfield in forum Video ConversionReplies: 1Last Post: 4th Dec 2009, 03:46 -
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 13:58 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 14:47
