1 - I use the same media
2 - Everything ripped mainly commercial DVD on DvdShrink becomes playable
3 - everything authored don´t play
Is correct to assume a issue on files created by Encore or DVD power producer?
any clues will be appreciated. Thanks
Carlos D S
WebStudio Multimedia
Brazil -
1 - capture in premiere 6.5 thru firewire uncompressed video
2 - edit
3 - export avi without compression
4 - import asset in Adobe Encore 1.5
5 - Transcode to mpeg2 7mbps CBR Dolby AC3
6 - author menus
7 - check project links and errors
8 - Build DVD folder (I do not export directly to DVD media)
9 - DVD SHrink open DVD folder and burn with nero
Why the same media works when I´m ripping a commercial DVD and don´t authored DVD?
I cannot understand.Carlos D S
Brazil -
Try burning with something other than Nero; perhaps CopyToDVD or DVDDecrypter.
35 Mbit/s authored DVD to play on Blu-Ray player???
By meisnerboy2 in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 15:05 -
Authored blu-ray will not play in PS3
By pietermc in forum Authoring (Blu-ray)Replies: 3Last Post: 6th May 2011, 16:34 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
authored DVD freezing...but individual VOBs play fine
By Massa in forum Authoring (DVD)Replies: 8Last Post: 5th Jan 2009, 02:45 -
unable to play authored & burnt dvd on standalone player
By rancid in forum Authoring (DVD)Replies: 15Last Post: 10th Jan 2008, 20:24
