I need to capture a bunch of video segments from my Hi-8 analog camcorder, edit them (adding titles, transitions, etc.) and write them out to a SVCD.
I understand that the best way to do this is to capture the segments using VirtualDub, convert them to mepg2 using TMPGEnc, and write them to the CD-R using Nero in SVCD format.
When is the best time to do my editing? I am talking about adding titles, cutting out unwanted frames, adding transitions between scenes, etc. Should I do this after the capture (or course) and before the encoding into mpeg2? In essence I was considering using VideoStudio 5.0 to get one big avi file and then encode.
This sounds like the right way to do it, but isn't it cumbersome editing this huge file?
When in the workflow is the best place to do my editing?
Steven
Results 1 to 1 of 1
DV Workflow??
By anonymous_whatever in forum Newbie / General discussionsReplies: 14Last Post: 11th Feb 2012, 16:00 -
Workflow help
By magillagorilla in forum EditingReplies: 3Last Post: 7th Jul 2011, 13:35 -
Restoration hardware, workflow...
By Writech in forum RestorationReplies: 2Last Post: 26th May 2010, 10:41 -
Workflow format
By zapster in forum EditingReplies: 5Last Post: 20th May 2008, 10:40 -
Editing workflow for HDV/SD
By racer-x in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 21st May 2007, 06:50
