All,
Apple has made much hoopla over the fact the Quicktime 7 does the vaunted H.264 codec. I've been using ffmpegX do squeeze things down with H.264, which makes for better file sizes/quality than Xvid and Divx. These H.264 avi files play fine in VLC and Mplayer . . . . and they don't in Quicktime 7.
I have a feeling that this is because the H.264 file is in an avi container, and Quicktime 7 wants it in an mov container. So are there any plans to get ffmpegX to put H.264 in an mov container, or is there a bug with QT7?
Can anyone shed any light on this quandry?
Thanks,
-STS
Indeed, Quicktime 7 only supports H264 in MOV/MP4 containers, while mencoder engine only supports it in AVI containers. In subsequent versions it will be possible to overcome this barrier.
Something to try in the meantime (no guarantees that this would work):
Set the audio and video codecs to Passthrough, and save the result as a .mov file.
If that just creates another .avi file, you could try the ffmpeg binary to copy the streams from the .avi file into a new .mov file, like so:
/Applications/ffmpegX.app/Contents/Resources/ffmpeg -i (input file).avi -vcodec copy -acodec copy (output file).mov
Edit: that is, you would do this process on the .avi file generated by ffmpegX.
Matt
You can try MPEG Streamclip. The export to Quicktime function of MPEG Streamclip will encode with H.264 as a MOV file.
This requires Quicktime Pro.
H.264 to AVI wont play in Quicktime
By kerr1586 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2011, 10:49 -
problem with conversion from quicktime to h.264.
By savvyguy in forum Video ConversionReplies: 23Last Post: 19th Jan 2009, 20:49 -
Mpeg4 AVC H.264 viewer for iPhoto/Quicktime
By rajupatel in forum ffmpegX general discussionReplies: 2Last Post: 30th May 2008, 16:14 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
Problem exporting AVI to H.264 in Quicktime Pro
By newsclips in forum Video ConversionReplies: 2Last Post: 31st May 2007, 00:46
