I cannot get my Ilo DVR to write decently to rewriteable disks.
For some reason, after a program reaches 99%, it just kind of hangs there for about a minute before it manages to finish, and once the entire disk is complete, I find trying to play it, the sound drifts in and out, and things keep freezing up.
Can anybody else get rewritables to work well on this unit?
Have any of the firmware advances improved rewritable writing?
Or do I just have to accept that I can't use rewritables with this unit?
Post your question here
http://www.techolio.com/forums/phpBB2/viewforum.php?f=7&sid=9fc98c3f81dd29a32b3f363baaeebc91
ILO by ILO users. -
You are probably using an incompatible +RW disc.
I only record to the hard drive and +RW discs on my HD04. I picked up a 10 pack of HP 4X +RW from OfficeMax. The media code identifies these discs as Philips. Many others have been recording to Ritek 4X +RW discs.
My HD04 came with a FUJI +RW disc. If your unit cannot record to the included FUJI disc, it needs to go back to Wallyworld. -
Batchman
I have been using Verbatim DVD+RW disk's. Not one problem, whether the disk was erased. full, or not full.
Normando's last comment.
[Quote]
[You should do exactly that]
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 14:48 -
Need files to update ILO DVDR05/ZU cant find anywhere
By strbyz1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Aug 2009, 21:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06 -
Convert ILO DVDR04 into LiteOn 5005x!
By D'oh! in forum DVD & Blu-ray RecordersReplies: 16Last Post: 21st May 2007, 12:35
