    ok trying to burn a dvd from files, im using nero 6. When i get it ready to burn, i put all my video files in the video TS folder, then i click burn and it says:
    DVD-Video files reallocation failed. The Resulting DVD-Video might be unplayablel. Do you want to continue?
    I tried moving the files to different paths and still no luck. but other videos worked fine just not this one. any ideas? thx in advance
    USA
    I think there is something wrong with the VOB,IFO,BUP structure in your video file.
    You can do a Google search for that error and they suggest redoing the file, upgrading Nero, even downgrading Nero or using a different program to burn. In other words, no direct solution.
    If only that file had the problem, I would say it points to the file as the problem.
  3. just burn the audio_ts and the video_ts folders as data i got your problem all the time now i just burn as data bingo no problems no more
  4. dvd2one can correct this sometimes by creating new files.
  5. I had this exact same problem when trying to backup "Danny Deckchair" and "Girls Gone Wild." In the case of the latter, I simply ignored the error message and burned anyway and the disc plays fine. In the case of "Danny Deckchair" I could never get it to play on any player other than my PC. So I just decided to ditch the menu in DVD2ONE and now it plays fine.
    May 2001
    Are all your file names in capital letters? Or, you might be missing a .BUP file (or other files). Every .IFO file needs an identical .BUP file. Also, there has to be a VIDEO_TS directory and all the files must be in there.
    If you want to know, post the contents of the NERO compilation here so that we can examine it and help with your problems.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  7. Another problem is that nero insists on a menu file (Vts_XX_0.vob) for each titleset (XX). Normally most SA Players will just play the movie (Vts_XX_1.vob, Vts_XX_2.vob...) without any problems even if there is no menu file.
