I'm using virtual dub 1.5.10 and trying to convert raw avi file to divx. I am encountering 2 problems. One is I don't know how to load lame MP3 codec to virtual dub so that I can select it under the audio tab -> compression option. When I downloaded lame mp3, there are no setup or install files. Also when I do a conversion, my final divx file is upside down. I'm relatively new at this so any help would be great. Thanks
Simple answer, use 'Flip Vertically' from filters selection.
EDIT: For Lame, to install the ACM codec just extract all files and right click on the LameACM.inf and select Install.
To use, you select Audio, Full Processing then Compression and you should see it, at least with VD 1.5.10.
AVI once converted has sync issues. Please Help!
By Marts1988 in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2011, 01:45 -
Converted avi files darker than originals (avi to mp4)
By Hal05154 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2009, 19:06 -
avi files upside down
By nocash in forum Newbie / General discussionsReplies: 1Last Post: 26th Mar 2008, 07:13 -
Build 2.5.3200 - Successful AVI-conversion - Upside down image..
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 4th Oct 2007, 16:58 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
