I have some DivX movies (dvd-rips & screeners) at 640 x 480 and i want to be able to watch these on my pioneer DVD player.
1) What is the best quality format that i could use to accomplish this (XVCD, SVCD, SVCD...)?
2) Also should i use MPEG-1 or MPEG-2?
3) Which encoder would be best?
Sorry for the newbie questions i've only made VCDs before with Panasonic MPEG-1 Encoder and i want some higher quality movies. Also if you could offer some estimates on time for the best choices It would be much appreciated.
Thanx in advance
<font size=-1>[ This Message was edited by: uknow on 2001-12-13 18:45:55 ]</font>
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 9 of 9
1. You need to read the compatibility list to see what your DVD supports, then use TMPEGEnc to convert to the proper quality.
2. Answers to the left. -
This is a tough question to answer, because it depends on your DVD player. Click the brown "DVD Players" link to your left, and look up your make and model of DVD player. This will tell you what format your DVD can play. Unfortunately, some DVD players cannot play VCD or CD-R at all.
On my Apex 1500, it will play SVCD, but I cannot use fast forward. I find (through extensive experimentation) that the best format is X-VCD, with MPEG1 at a 2048 kbps bitrate. (encoded with TMPEG) This looks nearly as good as a DVD. -
Oh, should of mention my DVD player supports all formats except SVCD subtitles and DVD-R/RW.
So X-VCD sounds good. Any other suggestions? -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You maybe able to fix the no fast forward problem! This is caused by errors in the file you are burning. Not all players are affectd by these errors but Apex are for sure...
You can fix by running file through VCDGear before burning. Set for mpg - mpg and fix errors. Only takes a few min even on a slow machine. Or use VCDEasy also fixes errors but also converts the file to Bin/cue either works great for me. No more SVCD disks that won't fast forward or rerverse!
First of all the XVCD ratio is 352 x 240, is this a big difference from the VCD 352 x 240?
So would the SVCD be better if could rewind and fastforward?
By the way about how much bigger is the size of the file than VCD; also how much longer does it take to encode.
thanx again -
FYI my pioneer dv-525 dosn't have any problems playing, ff, or ,rw either VCD or SVCD.
Yea i didn't think the Pioneer would have any trouble with it either.
But should i encode in SVCD opposed to XVCD for my 640 x 480 DivX?
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 18:09 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
