Hi,
I'm going to take the plunge and purchase my first DVD Recorder. I have noticed the prices have come down significantly since the last time I checked, but I don't want to buy any old thing. I was looking at the Phillips DVDR70 ( http://www.amazon.co.uk/exec/obidos/ASIN/B0000A9YZT/qid%3D1114987864/202-5912861-8870227 ), but it seems to have such a mix of good and bad reviews online that I'm worried about getting it - apparently the multi-region feature on it is dodgy, too.
Anyway, here are a few requirements I'm looking for:
A decent brand name - not too hefty of a requirement, especially if anyone can recommend any good-really good recorders which have less brand recognition.
DVD-R recording compatible - ideally, I'd like one that can do both DVD +R/-R but if not, I'd prefer -R. I'll purchase a +R only one if it's good enough and at a decent price range.
Size - I'm not too bothered if it's around the size of a Phillips DVD70 (linked above) but I don't want anything noticeably huge.
Recording - something that can record my VHS tapes from my video channel when I play them on my VCR.
Price - I'm looking to ideally spend around £150, although I would go up to £200 if the machine is right.
Multi-region - preferably out of the box or very easy to make it so.
I would appreciate any and all recommendations, and anything I should look for as a requirement which I haven't mentioned.
Thank you.
http://www.amazon.co.uk/exec/obidos/ASIN/B00069YILC/qid=1114994415/sr=1-1/ref=sr_1_2_1...388381-2061249
liteon makes a good cheap recorder, granted it does have its share of problems. If you search this board for the "5005" I think its pretty much the same, only the 5006 has vcr+, or whatever its called in the UK. -
Another plus for the LiteOn 5005 is that there are reliable hacks that allow the addition of 3-hour recording and the defeat of Macrovision.
I have the Philips DVDR75 and the ILODVDR04 (hacked). The Philips was dead out of the box, I shouldve returned it, but sent it in for warrenty repair, it took them 5 months to fix it. I can't recomend the Philips. The ILO has bugs with 2 of the 3 inputs, but it's hackable and I worked around the input problem by getting a video selector. I did recomend the ILO to 2 friends and we all 3 have been happy so far. I don't know if you can get the ILO...
I don't know that any unit can meet all those criteria.
I would get a medion DVD recorder they are the best for the money. You can find them on ebay all day long for around 99.00.
Ok, it doesn't matter if it doesn't meet all the suggested criteria, I'm looking for any good recommendations. I have looked at Panasonic model here - http://www.amazon.co.uk/exec/obidos/ASIN/B00021DM84/qid=1115041665/sr=8-1/ref=sr_8_xs_...912861-8870227 - what's the difference between normal DVD and DVD RAM?
https://www.videohelp.com/glossary?D#DVD-RAMOriginally Posted by Zak
More info here:DVD-RAM
A recordable format supported by the DVD Forum. It has superior recording features but it is not compatible with most DVD-ROM drives or DVD Video players. It works well when set up like a removable hard disk.
http://www.digitalfaq.com/othervideo/dvdformats.htmIf God had intended us not to masturbate he would've made our arms shorter.
George Carlin
Suggestion on a good DVD recorder....
By emoci in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Dec 2008, 19:50 -
Is there such a thing as a good DVD recorder?
By ibex333 in forum DVD & Blu-ray RecordersReplies: 95Last Post: 25th Oct 2008, 20:00 -
Dazzle DVD Recorder - not good enough?
By OneSoccer in forum Capturing and VCRReplies: 3Last Post: 12th Jul 2008, 15:59 -
choosing the good dvd recorder ?
By cccf25 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th May 2008, 11:43 -
I need a GOOD VHS To DVD Recorder!
By Kimiakane in forum DVD & Blu-ray RecordersReplies: 11Last Post: 13th Dec 2007, 18:24
