Results 1 to 13 of 13
  1. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    Can somebody tell me where to find 3 disc DVD cases with a relatively "slim" form factor?
    I'm looking for something that is approximately the same thickness as a standard single disc case. It also needs to retain the normal "face" dimensions as a standard case.
    I've seen them with hubs inside each side of the case and a 'page' in the middle for another disc, like this:
    unfortunately, the one in this pic is a 4-disc case & NOT what I want
    Something that "stacked" the discs would also be OK, like this:
    except that,
    again, the one in this pic is a 4-disc case & NOT what I want
    The problem is that I thought I book-marked the site, but apparently I didn't.
    Hours of sifting through Google searches has yielded squat....
    I really don't care how the discs are arranged within the case -- I just want cases that hold 3 discs and aren't freakin' HUGE.
    I suppose it would be OK if the case was about a thick as 2 normal cases, but the whole point is to save some space.
    TIA!
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  2. I Bought some slin three disc cases at CompUSA (in the states of course).
  3. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    All I can ever find are the slim 1 or 2 disc cases when I go there.
    and their site is a ******* nightmare to navigate....
    I'll check tho, thanx.
    anybody else?
  4. If you can't find them here...they probably don't exist.
    http://www.sleevetown.com
    Happy hunting
    It depends on whether you want to just store your DVDs and never use them again or store them and actually have them play when you want to use them again. The type that you show that stacks the discs holds the disc on the edge which tends to bow the discs a bit over a period of time. This is a serious problem when you try to play them again. The other type in your picture is the one most professionals use. They support the disc from the center and also prevent the disc surfaces from being scratched which is another good idea if you want to play them again.
  6. here try this site they have a lot of options and prices are reasonable
    http://www.effectuality.com/index.shtml
  7. Found another site that has them at $24 for 100 cases.
    http://www.meritline.com/dvd-cases-dvd-storage.html
  8. Why not just use the four disc case and only put three discs in there?
    try svp
    The electronic components of the power part adopted a lot of Rubycons.
    Jun 2004
    Ferrara-Italia
    I guess he is in USA, so I don't think svp is a good choice for him
    Sorry, I had to go see about a girl
    May 2003
    Peterborough, England
    As he hasn't bothered to say where in the world he is, he'll get inundated with useless information. Try http://www.blankdiscshop.co.uk/acatalog/dvdcases.html
  11. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    Originally Posted by RabidDog
    Why not just use the four disc case and only put three discs in there?...
    because that's wasteful and inefficient.
    I'm in the US.
    thanks for all the suggestions everybody, keep 'em coming if you got 'em.
    Jul 2004
    Tucson, AZ
    I ordered some of these triple cases from Effectuality, and I love them. They are exactly the same size as a regular single case, and they are $.45 plus shipping. They also have a quadruple case in the same size.
    https://www.effectuality.com/store/item.php/name/Triple_DVD_Cases/product/view/itemid/...tore/us/lng/en
