I have a DVD-RW / CD-RW combo on my desktop as a second drive. The other one is DVD-ROM. DVD-RW is HL DT ST DVD-RW GWA 4040B.
I have copied CDs on this drive before and make CDs out of music on my hard-drive. But of lately, I have not been able to author any CDs. I can still authur DVDs on the same drive, but not the CDs....![]()
Any suggestions..??? Thanks in advance.
Results 1 to 15 of 15
Hi
i had this same problem in the past, after a while my drive stopped recording cds.
I reinstalled INCD and that solved the problem.
hope this will help -
have a look here
http://www.nero.com/en/InCD_4.html
i was using nero 6 ultra and my drive stopped authoring cds i tried burning cds using the windows explorer interface and that didnt work either.
after that i reinstalled incd and everything works fine now -
Thanks Ricardouk...
I will try it out. I do have Nero 5.0 which I had been using to author CDs. -
You're welcome!
just let us know if it worked. if your drive came with nero 5.0 i reckon incd should be on the nero installation cd, it was on mine. -
Installed InCD. (it was with my Nero 5.5 CD). But still no luck....
I tried authoring a CD by Real Player, but still could not do it. Irony is that I am able to copy DVDs on the same drive. Any suggestions..??
Thanks -
CD+R's? I thought they only made CD-R's.
www.cdbaby.com/djtedness -
the same happened with me on my lg 4081b,reinstalling incd solved my problem.
does it display any message when you're unable to author the cd?
try doing it with nero,if it fails it will ask to save a log of what happened during the process, then post that log here and someone wiser than me might solve your problem by looking at the log.
if your software is not "communicating" with the drive this might solve it
http://www.adaptec.com/worldwide/support/driverdetail.jsp?cat=%2FProduct%2FASPI-4.70&f...a2.exe&sess=no
this utility mediates between your software and your drive,if by any reason its gone, it might be the reason why its not burning cds.
that same utility will enable you to find out if your version of ASpi that you have on your pc is the right one
Im not an expert on this things, just sharing stuff that i think are right
good luck -
No, the whole process goes on as it should. There is no error message after the burn is completed. It says " burn successful", but when I get the CD it is still blank. Same happens with RealPlayer burning.
You can't they don't exist. There's a CD+G format which is typically used for karaoke CDs, but these are just ordinary CD-R/RW discs.Originally Posted by richdvd
I installed the ASPI from the website. Still no luck..
I can read CD audio, but cannot copy CD. -
Sounds like you are only doing the "test" burn and not actually burning the disc. check you options when you enter the burn menu...there are check boxes for burning the disc and testing.
Google is your Friend
Need help using Nero 7 writing
By tcory in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2011, 16:19 -
Problem writing on BD-R with a Lacie d2 Blu-ray burner
By L7dra7 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2008, 22:03 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 17:38 -
Problem Writing Dual Layer (first time attempting DL)
By brett0973 in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2007, 22:46 -
Problem writing to Philips dvd-r.
By jackrussell in forum MediaReplies: 0Last Post: 13th Jun 2007, 06:41
