Hey, i'm kinda new to this but i know how to make dvd's etc, but lately i've been having a problem with my dvd movies going out of the screen. I convert my avi files using vso's divx to dvd, 4:3 aspect and NTSC format. After that i made menus with dvd-lab pro. After it was done, I played it on my ps2 and my stand-alone dvd player. The results were pictures showing, but it seems to be bigger than the tv screen, both on regular size tv, and widescreen tv. I also tried authoring with TMPGEnc dvd author, but same problems. It's like it's only centering on 95% of the picture while the rest is gone due to not showing up.
I played the dvd on my comp using PowerDvd, and the whole picture shows up fine. Any suggestions?
Do a search on overscan and you will find an answer.
If you use TMPGEnc to encode the video, you can use overscan compensation, which means you slightly shrink the image to about 90% of the total resolution. This will result in none of the video being cut off by overscan.
However, generally speaking, overscan does not neccessarily hurt a movie. it cut's off a relatively small part of the image. it is very annoying, though (as is interlacing) which is why i usually watch movies on my computer instead. No overscan, no interlacing.
yeah.........asdf -
https://www.videohelp.com/glossary?O#Overscan
Overscan
The area at the edges of a television tube that is covered to hide possible video distortion. Overscan typically covers about 4 or 5 percent of the picture.If in doubt, Google it.
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 15:13 -
change screen size of rmvb video
By vcd_user in forum Newbie / General discussionsReplies: 0Last Post: 28th Jan 2011, 11:47 -
How increase the size of the video in screen TV with the ConverterXtoDVD?
By Codonauta in forum Video ConversionReplies: 9Last Post: 21st Jan 2010, 17:31 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 05:33 -
what screen size for video in phone???
By askformore in forum Portable VideoReplies: 1Last Post: 6th May 2007, 20:24
