  1. Ok, the situation I have:
    I record/stream video at proms, weddings, dances, etc. I run a VHS SuperCam. I've got a cable running from my video out on the camera to my audio rack to a projector, I want to come up with a solution to make the cable from my video recorder to the audio rack wireless, how can I do this?
  2. There are a number of so called 'video sender' units on the market. AFAIK, they only handle composite video (and audio) but these may do what you want.
    There are 10 kinds of people in this world. Those that understand binary...
  3. i dont think thats quite what im looking for, thanks though
    basically ive got a video out (bnc) cable to video in (coaxial) that I am trying to get rid of, connectors are not an issue because I have most adapters imaginable.. I am just trying to remove the cable that I have running from video out on the camera to video in on my switch box. I'm only sending video.
  4. Well, the type of unit I described handles composite video on one cable, and usually stereo audio on two others, so there is no problem using them for video only. Your video out is BNC, so that is probably component or RGB, so this may not be suitable in that case. I would be surprised if there were not proffesional equipment that can do what you need, it all depends on what you want to spend.
  5. Under a grand is my budget.. ($1,000)
    Any clues on where to look for it?
  6. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Go to http://www.cyberguys.com and do a search for item number 2040885. I think this is the kind of thing you're looking for.
    Buy My Books
  7. Melonpool, thats basically it, just looking for a very high quality version of this.
    THANKS!
  8. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Actually it's Gadgetguy. Melonpool is my favorite Webcomic. Check it out at www.melonpool.com
    Back on topic...
    Check this site
    Buy My Books
