i use vidi in osx often. it works perfect. but i need an app to transfer dv in os9.
i have been using my g4 as a vcr for some time using vidi and a dvcam. the dvcam is hooked up to a digital cable box. i set the timer in vidi and then watch the show later.
recently i have had to remove the g4 from this location and only have an older final cut pro machine that will only run os9 left to complete this task.
the machine runs well, an old 9600 with g3/500 cpu but osx doesnt work well on it at all. i have done hours upon hours of non-timed dv transfer in final cut pro on this machine.
i've never found software that will do timed dv transfer in os9. is there any?
BTVPro and TV Reminder work quite well together in OS9:
http://www.versiontracker.com/dyn/moreinfo/macosx/7714
http://www.versiontracker.com/dyn/moreinfo/macos/8350 -
those look like they will work! thanks.
took a few days of looking at the apps to figure it out, it looks like BTV will do it by itself.
i got kinda spoiled with vidi as i used it to record hundreds and hundreds of hours of tv for later viewing. -
You only need TV Reminder if you want to schedule BTVPro to record when you're not around.
Name of Application
By PC_Tek in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2010, 16:54 -
Application Error
By Jmorales27 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 10th Jul 2008, 15:35 -
Where is the coupon application?
By moviebuff2 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2008, 14:15 -
COLOR application
By Tom in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 01:09 -
reg the application to use
By liddu in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2007, 04:31
