  1. i need some help. im trying to author my first dvd. im using dvdlab and im following the instructions from someone on this site. the instructions are great. pictures and everything. i got to the point where i can make my menus with motion chapters. so my menus have 6 chapters on each menu. i selected each chapter and set the start point of the clip and set them each to 10 seconds and then i hit the render botton. now in the tutorial it says this should just take a minute. but what it does is it starts on the first chapter and scans thru the whole movie then goes to the second chapter and scans the whole movie again and it looks like it will do this for all 6 chapters. now i have a total of 3 menus and 15 chapters. this seems like it will take hours to do this when the tutorial says it should just take a minute. what am i doin wrong? why would it scan the whole movie when i select render? why not just 10 seconds for each clip like i want? i like the program and all the cool effects i can add but i cant get past this issue. any advice would be appreciated. thanks
    Apr 2004
    Miskatonic U
    It would help if you linked to the tutorial so we can see where you might be going wrong.
    Read my blog here.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Are you sure that you set them to 10 seconds ?
    I create my menu backgrounds outside DVD Lab Pro and just use it to author, so I can't offer you much more than 'check your settings again' and check the mediachance forums. If it's a bug, it'll be covered there.
    Read my blog here.
