Hi
How does Windvd record what off of your camcorder or VCR and burn it on a DVD? Doesn't it need to convert the video files to MPEG-2? If it does convert, is there anyway of editing the video first before burning on DVD?
Don't know about WinDVD, but there are many other apps to use for capturing (depending on what capture card/solution) you use.
/Mats -
Well it comes with the HP media center. So is why I was asking. Which then is the best one out there to do this?
Again, what to use depends on what capture / TV tuner card you've got. Don't know what's fitted in the media center box.
/Mats -
If your'er talking about Intervideo Windvd creator- it's kind of lame. Even with a hardware encoder this program re-encodes the entire video when you compile or author the dvd-dumb!
Don't know what capture card you have with those media center's but wouldn't surprise me to see a "software only" solution.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
