Results 1 to 9 of 9
    Feb 2003
    Calgary, AB Canada
    When you have a movie open in QT player, and press 'command-I' or go to 'Window/Show Movie Info' from the menu bar, you get a window called 'Movie Info' that displays various stats about the movie thats open.
    In quicktime 7, the framerate (fps) reports 30 instead of 29.97 for NTSC content. It doesn't matter what format ... mpeg2, mpeg1, divx, 3vix.
    I use this info to determine if movies are truly ntsc compliant or not.
    Anyone else having this issue? Anyone have a solution.
    thanks.
    Feb 2003
    Calgary, AB Canada
    Geez, won't anyone even confirm this problem?
    visit my photo retouching website: http://www.shiftstudio.ca
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Most of us have NOT upgraded to QT 7 due to the MPEG-2
    component, as well as making sure we can get work done.
    Sorry we cannot help....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  4. Originally Posted by terryj
    You can use the V6 one 8) It works...
    Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
    Your source for iMovie answers and what not! ;-)
    Feb 2003
    Calgary, AB Canada
    Yup, I upgraded to QT7, didn't update the mpeg2 component, and mpeg2 still plays in qt player etc.
    Jun 2001
    Silver Spring, MD USA
    Probably not, as its not a problem.
    If I recall correctly, a framerate of 29.976 is used for interlaced content, and 30 frames per second is used for progressive content -- and both are true NTSC framerates. It has something to do with household current in NTSC countries being 60 Hertz.
    It's boring and complicated, but not a problem.
    Feb 2003
    Calgary, AB Canada
    Hmmm.
    Well in qt 6.x, if qt reported 29.97 fps, you are good to go for vcds, dvds ets. If it reports 30 fps, the file isn't compliant, and some sort of timeshift telecline must be used.
    In any case the same files in qt 6.x report 29.97fps.
    I just wonder why they are reported as 30 fps in qt7?
    -- sdm.
  8. I upgraded to Tiger and QT7, but kept my Quicktime 6 around (to use Pro features). If I open a movie in version 6 and check its frame rate, it appears as 29.97. The same movie opened in Quicktime 7 reportrs a framerate of 30 fps.
    Apparently the actual frame rate is either not important to Quicktime, or version 7 is misreporting it. Note: the movie was created in version 6 at 29.97 fps.
  9. Master of my domain thoughton's Avatar
    England
    Another yes here, my QT6 mpeg2 decoder still works in QT7. I dunno about the QT framerate reporting issue, but I have converted a few NTSC eps recently, using QT to decode, without any sync problems.
    Tim Houghton
    Website • Photography
