ok i used fit cd to see how i should convert my 80 min .avi file into mpg-1. and i could do that and easily fit it on a 800mb cd with 1045kbs video and 112kbs sound. and so i encoded with tmpgenc. but instead of being 670mb it was 808!!!!!!! now i encoded one at a time. the movie and sound. now apart it was the right size. but combined it was much bigger. and i encoded as one, whole file. it came out 808. is there anything i can do??? i'm gonna de-mux it and join em with some other program. but please reply cuz i doubt this will work. thanks alot.
Remember that you can fit about 800 MB on a 80 min cd if making XVCD and if you overburn some seconds it might fit.
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 15:13 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 20:04 -
Why is my edited video file bigger than the original?
By baebbe in forum Newbie / General discussionsReplies: 8Last Post: 28th Jul 2008, 16:44 -
AutoGK - Bigger file = better quality?
By kelemvor in forum DVD RippingReplies: 13Last Post: 8th Jan 2008, 23:15
