  1. Hello Everybody,
    I'm in a need a simple program to tell me what media is in my drive. I have a few "Import" DVDs (if you know what i mean) and i want to find out if the are DVD-R, DVD-RW, DVD+R, DVD+RW.
    I once had a program that did this, but i can't find it and i can't remember what it was called. It would be alot of help.
    Thank you,
    -Danny
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
  3. Your Sony DVDR might be LiteOn OEM. If so, Kprobe would do the trick.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  4. Member daamon's Avatar
    Melbourne, Oz
    I've used DVDInfo Pro and would second that choice. I've not used Kprobe but regularly see people recommending it, especially for LiteOn drives.
    And welcome to the forums.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. Hmm, DVDinfo PRO - in the tools section it is writen "Freeware, 20$" - is it free or 20$
    I am using DVDDecrypter for the task - not full info, but what I need to know is there....
  6. Thank you all for your help. I've tried all of the suggested programs, none of them seemed like the program i used before. However, I do like DVDInfoPro, it does exactly what i need it to do.
    Kprobe would be my second choice, i use both of them and get a feel for all their different features.
    Thank you again for such a excellent respones.
    -Danny
