I use MPEGs with DD 2.0 audio as assets and I can't find a way to get to encode to DD 5.1 for final output.
I thought Encore was capable of outputting to DD 5.1 !?!?
Any suggestions?
Thanks in advance!
It is capable of authoring dd5.1 assets, but I don't think it can encode them. If you only have AC3 2.0, what do you hope to gain ? You just dump in 2 channels and get back 5, it doesn't work like that. You are better off leaving it as 2 channels unless you intend to take the time to make a true 5.1 mix.
Read my blog here.
Thank you, guns1inger!
You're right.
You know? I am kinda novice (well, sort of) at all this authoring business. So, please bear with me.
I am slowly moving from TDA to Encore, 'cos of the many limitations TDA has posed so far.
I wanted to have more freedom with menus, and TDA is what it is, which means "good" if you just want to author a DVD with a few buttons clicks. But, it leaves a lot to be desired!?!?
Anyway, the DD 5.1 idea was that I thought it would give me some extras on the audio side. But, reading a few web articles, including lordsmurfs' own article on the subject, I do understand that unless I have 5.1 assets, I won't increase the quality of the output.
Going back to Encore, I am having audio problems of other sorts and I am wondering if you or anybody on this great forum could help me out
The sound gets distorted after authoring.
My asset is an MPEG from TV program recorded on my standalone DVD-Recorder. So, it has DD 2.0 audio already encoded.
I did trim off the ads in TMPGEnc Mpeg Editor and the audio of the MPEG file is fine. Perfect sync and quality.
However, in Encore, it gets distorted. It sounds as if it was a voice from the other world, if you know what I mean.
I can't set the transcoding to "do not transcode". So, I leave it to auto, and the preset is PAL DV High Quality 4Mb VBR 2 Pass.
Well, if you or anybody else che help me out, I will be infinitely grateful
Can't Open Encore
By koberulz in forum ComputerReplies: 0Last Post: 4th Apr 2012, 02:53 -
Encore help
By Entengdigital in forum Authoring (DVD)Replies: 8Last Post: 5th Sep 2011, 21:08 -
Encore enutv-2
By smartel in forum Capturing and VCRReplies: 2Last Post: 15th Jan 2011, 16:15 -
11 Extra GB in Encore
By koberulz in forum Authoring (Blu-ray)Replies: 3Last Post: 6th Sep 2010, 06:08 -
Help in Encore
By sk8_aholic in forum Authoring (DVD)Replies: 0Last Post: 13th Nov 2008, 00:33
