  1. Ok here is what i want i want to make some small stop video's. I got a bunch of pictures now and want to make a stop motion video. What software would you recomend for taking the photo's and making a video with them, wanna basically control everything. Price no object.
  2. Vdub will take sequencially numbered images and let you save them as AVI, or you can frameserve to a program like TMPGEnc to convert to MPG.
    Apr 2002
    Oskeeweewee Ontario
    The Adobe line of products might be of some use...
    Lots of support, and usergroups out there..
    You can do lots of the stills preparation in Photoshop, do your video timeline with Premiere Pro, and fancy titling or advanced composting (effects) with After Effects...
    As far as titling goes, there's many cheaper alternatives if you don't have time to learn After Effects...
    Good luck!!
  4. thanks i am gonna check these out
