How do I tell premiere 1.5 to display my entire .bmp or .jpg files without any stretching or changes to the image.
When I look at the monitor window its zoomed in the center of the image as well as the sequence window.
I looked at the interpret footage, its set to "use aspect ratio from file", but it only displays a small portion of the center of the image.
Any ideas what I'm doing wrong?
Thanks!
Matt
You need to tell Premiere to do this when you are creating a project. When choosing project options go to Custom Settings> General and put a check in the box that reads Scale clips to project dimensions when editing to sequence. That should solve the problem.
You can also scale individual clips (like still images) by:
1. Clicking on the clip (image) on the timeline.
2. Select the Effect Controls tab in the Monitor window.
3. Select the Motion effect under Fixed Effects and adjust the Scale.
Image display help on LCD TV
By David Montanaro in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2011, 11:16 -
connect pc to tv and display image on both screens
By gordes04 in forum ComputerReplies: 11Last Post: 23rd Sep 2010, 07:02 -
VLC problem - doesn't display full length, only plays bits...
By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 14:38 -
mov to flv display image
By markarcaro in forum Video ConversionReplies: 2Last Post: 14th Feb 2008, 07:29 -
Can a Sony "full HD" TV (e.g. KDL-40D3500) display 1920x1080 via
By acnurb in forum DVB / IPTVReplies: 5Last Post: 26th Jan 2008, 00:59
