Hello again all,
I have a couple of questions so this may get a little long winded. Bare with me!!
Ok. I have two computers. An AMD 2000 and a P3-733. Two hard drives (a 80gig and a 160gig (with about 45gig taken). I have 1 dvd burner and 1 cdburner. What I would like to do is take the 80 gig, format it and plop it in the P3 with the cd burner to use as a general every day computer. Then leave the 160 with the dvd burner with the AMD.
Now, because the 160gig has about 45 gig worth of stuff on it, I dont want to format. So, my questions are as follows:
1) What is the preferred method of installing XP on said drive without screwing up/losing any of the data presently on there.
2) What is the loss of quality and/or time, if any, when burning/shrinking to the same hard drive (C) as the OS and burning/ripping program is on?
I think this makes sense. At least, it does in my brain .. but thats not saying much :P
As always, I think you in advance for your time and advice.
Thanks,
LG
Firstly, I would just purchase another drive and save yourself a lot of problems.
But... If not, I would defrag the 160G throughly. Then backup important data, just in case...
Then just install the OS on the existing partition. I assume it's a data drive and doesn't have a OS on it. Should not damage any data already there.
Another method might be to create a new partition on the drive with Partition Magic (Or similar) and install the OS there. Haven't tried that, but should work. I'm not a fan of multiple partitions.
As far as one drive VS having two on a computer, two is always better. The difference in speed and efficiency depends on your IDE controller, how much data is on the drives and probably a few other things. -
what is the point of multiple partitions, and how do they work?
What We Do In Life, Echoes In Eternity.... -
From day one I have been using multiple partitions. I have used it so that I can keep the data separate from the operating system. I have my system setup so that everything is on separate partitions.
- Win 98
Music
Photos
Downloads
Web hosting data
With this method it is easier for me to store and keep track where items are.
Also if I forgot what something is called I at least know what partition it is on and it keeps searchs easier.
So that is why I use multiple partitions. Easier housekeeping.SeeYa
Never Say Never (Romeo Void 1981)
Firefox, Thunderbird - Win 98
Fat32/NTFS External Hard Drive Formatting Questions.
By bbanderic in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2010, 21:13 -
What kind of Hard Drives should I get to complete my editing setup?
By ercdill in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2008, 14:15 -
Setup the hard drives please
By Dash1 in forum ComputerReplies: 10Last Post: 17th Dec 2007, 10:28 -
Cable questions for new setup
By LT9000 in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2007, 20:41 -
Laptop->TV setup. Video out and IR questions.
By akrako1 in forum Software PlayingReplies: 10Last Post: 28th Jun 2007, 13:01
