Does anyone know of good software that will create a new menu for a standalone created disc? I am also looking for something that will join two standalone dvds together and create one full dual layered disc, preferrably with editing functions (I guess VOB file editing fuctions). I tried searching the forums but didn't really come up with what I was looking for. Thanks in advance for the help!
DVD Remake Pro can help you out with "joining" two separate DVDs to one dual layer disc. As for creating menus, TMPGEnc DVD Author is my tool of choice.
If in doubt, Google it. -
And of course using TMPGEnc DVD Author 1.6 w/AC3 plug-in you can import two DVDs from your standalone and create a D/L disk with new menus and only have to learn one easy to use software.
I do it all the time. I Standalone to a RW disk, rip into computer and re-author with new menus. Then I re-use the the RW Disk.
Cheers
What software burns avi to dvd without having to convert??
By bradztheman in forum Video ConversionReplies: 3Last Post: 20th Jan 2012, 20:41 -
How to create edited DVD that will play on standalone player with menus
By bahjan in forum User guidesReplies: 0Last Post: 26th Mar 2011, 15:39 -
Best avi to dvd software that burns
By mol3000 in forum Video ConversionReplies: 1Last Post: 19th Aug 2010, 00:19 -
How To create new dvd's with menu's from existing ones from standalone unit
By bidelman in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 17:01 -
DVDFab -- DL burns don't work in standalone
By eclipse95 in forum DVD RippingReplies: 9Last Post: 19th Feb 2008, 17:48
