Results 1 to 12 of 12
    Jan 2003
    Nassau, Bahamas
    what does " index of scan line is out of range(320)", i got this message when trying to enencode an avi movie in tmpgenc, can some tell me how to fix it
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    Jan 2003
    Nassau, Bahamas
    so theres no one who can answer this question for me...i get this regularly, doens't anyone else
    May 2001
    I'm still trying to figure out what "renage" means.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Sep 2003
    Northern California
    "What the hell does 'renage' mean?" exclaimed Johnny Quest to Hadji. Suddenly Bandit, Johnny's dog, leaped up and bit his larynx so he couldn't ask stupid questions anymore. So there was only one thing to do. Namely, kill them all off. It was a lucky thing for the Wiggle that a meteor was moving towards the Earth. Really, really, fast.
    so there...
    Jan 2003
    Nassau, Bahamas
    come on guys all fun and jokes aside, this has been botrhering me for some time now, with some of my avi movies..holla back if you know what that means
  6. I thought it was a typo that should read "range".
    But even if it said "out of range 320" I wouldn't have a clue. Although 320 might be referring to a resolution. What are the avi specs?
  7. Do you mean "Range"? I would say it has somthing to do with the "Video Size" aspect ratio.
    What are you starting with? and trying to end up with?
    Try to post a Gspot screen shot of the "Video File" Info.
    May 2001
    Well, he's responded to his original post twice, and didn't bother to clarify what "renage" means (or that it was a typo). I therefore have to conclude that "renage" was the word he wanted to use. I have no idea what an "out of renage" error refers to.
    Maybe if he "cut and pasted" the error (or even took a screen pick of the offending error), he could eliminate any typos on his part, plus we would probably get the correct error context.
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Probable causes: Bad source file. Followed closely by Bad codec.
    /Mats
    Feb 2005
    Houston, TX
    You might want to go back and look at SIRCOOKS's original post. It seems he did use the word "range" and not "renage" as you've been suggesting.
    As to his quesition, SIRCOOKS might want to run it through google. There are some entries on the TMPGEnc and Club Freaks forums that might provide some useful information.
    f
    May 2001
    If you look closely, you'll see that he edited his original message as follows:
  12. Originally Posted by SIRCOOKS
    Yes, you are the most important person so someone must come and help you with your problem... Since no one has been able to give you an answer, then yes, the reason for that must be because there is a conspiracy against you.
    You can help yourself by providing a little bit more information. For example, the specifications of your source media file. What are your encoding settings. Etc.
    As a shot in the dark, I agree with mats.hogberg. It is probably a source file or codec problem.
    Regards.
    Michael Tam
    w: Morsels of Evidence
