well now i figured out how to create vobs from avi, mpeg1 etc and burn them to dvd, but what about movies over 2 hours long which is about all these dvdr can handle isn't it or can i put something say like 2hr 20 mins on it not the dual layer.
Determine bitrate based on length- use a bitrate calc. and set encode bitrate to achieve the 4.4 gig limit.
OR- run your compiled dvd folder thru Dvd Shrink as long as it's ~ 20% shrinkage you shouldn't notice a quality degredation. -
I will second the vote for DVD Shrink. I've done this many times and it works great.
JML -
It's always better to encode to the right bitrate (=the one that lets you fit the movie on your media) than to encode at a random high bitrate and then shrink.
It's very simple to operate a bitrate calculator. No excuse not to use it.
/Mats
How to get 10 hrs SD footage onto BD?
By ruffhouse in forum Authoring (Blu-ray)Replies: 52Last Post: 16th Nov 2011, 14:25 -
Why does it take 10 hrs to encode a film using handbrake?
By jones24 in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 16:53 -
8 hrs of Avi to DVD with Menus
By randolphsw in forum ffmpegX general discussionReplies: 10Last Post: 7th Feb 2008, 20:31 -
shortest way to encode 5.5 hrs of avi's using tda3
By cduval04 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jul 2007, 13:38 -
creating a dvd using idvd 5 of a movie around 3 hrs?
By tab75-13 in forum MacReplies: 2Last Post: 1st Jun 2007, 07:12
