I just upgraded my 4x dvd burner to a Pioneer 16x burner. Im happy to burn at 8x because most likely 16x will skip when watching a movie. My burn times for 8x is about 7:30. When I burn at 12x the time is under 6 minutes. Does that time seem about right? I noticed that the burner does not start out at 12x but it works itself up to that speed. Is that normal? Thanks.
Catman
Yes that's normal,the reason it speeds up is because it writes in Z-CAV(steps) or writes in CLV(steady increase).
If you are using Dvd Decypter, then the speed does work it's way up.
I'm not sure about other burning software.
Also...your times sound normal. -
Originally Posted by Catman209
On my NEC-3520 I get excellent results burning Verbatim 16X DVD+R at 16X, just the way the media and drive were designed to do.
My point is, it's worth the cost of one or two discs to test your theory yourself, rather than basing your expectations on what other people have reported.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 00:36 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 20th Sep 2008, 23:35 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 01:38
