Years ago when I burned one of my own films onto VCD, I authored them slightly incorrect audio-wise.
I edited in Premiere from DV footage at 32kHz. However, I imported music tracks at 44.1KhZ, exported the final movie as an AVI at 32kHz and then converted to a VCD-compliant MPEG using TMPGEnc. This resulted in the music having a rather annoying, sustained ringing sound over it. No one really notices but to me it stands out like a sore thumb.
My question is: is there any way to reverse this trait? Or has anyone had any similar experiences? Needless to say, for a while now I make sure all my frequencies match when I edit!
Thanks a lot.
You could extract out the audio and try running it through Audacity. Play with the filters and see if you get any improvement. It's a free program.
Usually this type of audio filtering degrades the audio somewhat, but it's worth a try. Other pay programs may do better.
An app that views audio's frequency (Hz)?
By firebo14 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2012, 20:34 -
fine-tuning a fix for this audio buzz-ringing
By spiritgumm in forum AudioReplies: 12Last Post: 3rd Nov 2010, 22:08 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
How do I remove a bad frame from a video without VirtualDub or DivFix?
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 11th Dec 2008, 20:07 -
Pinnacle Studios 11 - Low Frequency Audio Hum
By notheldge in forum Capturing and VCRReplies: 9Last Post: 15th Aug 2008, 13:07
