what are some of the negatives and positives between a hub and a switch
Results 1 to 13 of 13
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
Hub= cheap, easy to run diagnosis and sniffing. Bad-More Collisions on Network
Switch= Low Collisions, higher end switches can be managed and monitored, and segmented into routed subnets. Bad-Cost
For a small 4-8 port ethernet hub/switch the cost should be almost the same. -
Hubs are generall cheaper but they do not organize the flow of data between computers like switches and routers do so you sometimes see packet loss. Most commonly you will notice lag more often in gaming with a hub than with a router/switch.
Switches/routers are a little more expensive on average but they "direct traffic" for your network so they are a bit more efficient. IIRC there are no gigabit copper hubs, only switches.FB-DIMM are the real cause of global warming -
i ask this because my hub just cut out oin me and i dont know why, ivebeen trying to reconfigure but it just wont happen, so i bought a switch, but im not gonna open it until i try to get the hub back up...any more pros and cons
For a small workgroup (8 computers or less), the cost difference between a hub and a switch are minimal. I'd recommend a switch.
Nothing can stop me now, 'cause I don't care anymore. -
Ahh, something I can finally use from Networking class
First things first, realize that hubs are essentially antiquated technology. While switches used to cost big bucks, 8-port 10/100 switches can easily be found for under $20. Why are switches better than a hub?
Well... as rally was pointing out, ethernet is a collision domain network. With a hub, every time a packet is sent out from a PC, EVERYONE on the network receives it, but only the target of the packet will use it. Not only does that waste bandwidth and cause packet-loss due to mass collision potential, it is extremely inefficient, especially for latency-sensitive gaming.
With a switch, it keeps a table in its memory of what every MAC address that is hooked up to it. When it receives word that a packet is about to be sent, it will direct that packet to the target... and no one else will get it. No wasted bandwidth, no nonsense. Plus, switches come in Gigabit flavor now (around 125MBps transfer possible, not like your HDD could sustain that rate anyway
... this is compared to what a normal 10/100 switch can do, which is around 11MBps).
As everyone was saying, go for the switch! www.newegg.com has some nice prices...Your base? Well, they belong to me now... -
Another option, most routers these days actually have a switch built in (usually 4 ports). I LOVE my GbE switch (although for some reason it doesn't like the PRO 1000/MT NIC built into my main desktop.
But it comes in handy whenever I'm transferring large files or lots of files from one server to another. Gigabit NICs can be found retail for $30 and even cheaper online. However, if your network usage isn't high, 10/100 will be more than adequate.
now im having trouble because one comp cant logon to the other, but the other can log onto the one which cant log onto it, any ideas
I always suggest modifying the LMHost file on p2p networks
what the hell is that, where do i find it, and what must i do with it...holla back
also, is there some type of reset button i can hiy, to reset my network, right now im still tied to the old two computer names, and i think a reset would do me good...holla back asap
system32/drivers/etc
open LMHosts.sam with notepad
Remove everything except your computers IPs and names along with #PRE
save it as "LMHosts"
right click my computer select properties
select network identification
change your computer name to what you want
update lmhosts file if you edit it before you change comps names -
but what would doing that help me to do,....holla back asap, i allready have my switch hooked up,
WD TV Live Hub First Impressions
By TBoneit in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Nov 2010, 16:09 -
New WD TV Live Hub
By stiltman in forum Media Center PC / MediaCentersReplies: 8Last Post: 4th Nov 2010, 15:25 -
Removing Hub Labels
By rvman in forum MediaReplies: 10Last Post: 3rd Jul 2008, 13:06 -
TY R47WPP600SK -- hub printable or not?
By spiffy in forum MediaReplies: 6Last Post: 12th Mar 2008, 22:03 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 10:23
