  1. How many MB/S does an XVCD file take if it is 2500-3000 kbps?
    And how many MB is an average XVCD 1.5 hour movie?
    I need to know this so that I can properly cut the movie to fit it on CDs.
  2. At that bit rate, you are looking at about 23+ MB's per minute -- or ~35 minutes per 80 minute CD-R. So a 1.5 hour movie would take roughly 2.4 GB of space on 3xCD-R.
    If you don't want to cut these MPEG's by hand -- and you are not too fussy about where they break -- then you could demux them and mux them back using bbMPEG or TSCV. These tools will cut the MPEG up for you.
    Good luck,
    - bewley
    baby bewley's Eclectic [mp3Pro] Rock
    http://www.live365.com/stations/230630
    <font size=-1>[ This Message was edited by: bewley on 2001-12-13 12:32:48 ]</font>
  3. Use the FitCD Tool available at
    http://www.chizzil.com/softdetail.cfm?ID=699
    (link to FitCD on the VCDHelp Tools Page is dead)
    On an 80 min CDR, 2500kbps will enable about
    41 minutes, 3000 kbps will enable about 34 minutes.
    vcddude
