I have some AVI Divx files that I used the DivxtoDvd program to convert. That got me a VOB file. I know want to take 3 or 4 of these files and get them on a DVD with a simple menu. I have access to a few DVD Burning programs but am not sure exactly what the VOB file is.
I tried Premier Elements and it didn't recognize the VOB file as media. What program should I use to bring the VOB files in and create a DVD with a menu? These are just TV episodes that I want to save....
Thanks.
These Vob files do they have corresponding ifo and bup files etc?
if so they all need to be in a folder called VIDEO_TS then burn them with nero. You can't mix n match though, the ifo and bup files etc correspond the the vob files created with the program you used you need them all to create a dvd.I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx) -
You can import the vob files into a DVD authoring program that accepts them and then add meus etc. I would suggest TmpGenc DVD author for this as this also allows you to trim the files if needed. DVD-Lab accepts VOB files to.
There are 10 kinds of people in this world. Those that understand binary... -
The file is in the Video_TS folder but it is all alone. Just the one VOB file and that's it.
Does TmpGenc DVD Author do the burning as well or is it just for creating the files and then I'd have to burn it with something else? -
I'd go and try what Bugster suggests
Playable DVD by using VOB files
By vikas.babu in forum Authoring (DVD)Replies: 3Last Post: 25th Feb 2011, 04:33 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
How to turn all the video files into one title in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2009, 07:11 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
