Results 1 to 12 of 12
  1. I use dvd43 for the compy protection on to backup my dvd's. And when you put in a dvd then put the cursor on the smiley face in the task bar it says something like 1/1 dvd found. But on my parents computer it says 1/2 dvd found and when I try to back it up it says it cant because its copyrighted. I use to work but now it wont, whats wrong? I have uninstalled and reinstalled but still nothing.
  2. which app are you using to back the dvd up?
  3. I use nero. It works fine on my computer and always worked on my parents untill all of a sudden. And I noticed the icon on mine says 1/1 dvd found, or something like that. And my parents says 1/2. Its like my parents is only finding 1/2 of whatever its looking for.
  4. Get AnyDvd this should solve the problem.
    I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
    Rufus T. Firefly (Groucho Marx)
  5. AnyDVD costs $40. DVD43Free works fine just started messing up on my parenbts computer all of a sudden. I dont want to change I want to know how to fix the problem and whats wrong.
    Feb 2005
    France
    are you using the latest version of DVD43?
    Jul 2002
    Up in yo' bitch.
    Sounds like your parent's computer has more than one DVD-Rom drive while your's only has one. I'm just guess here. What you may want to do is verify that DVD43 is looking at the correct DVD-Rom drive.
  8. We both have 2 dvd drives each. I fixed the problem, I updated her dvd43 software. Thanks for helping smearbrick1 and clairew since you were the only ones who offered actual help. Everyone else just offered a crap alternative.
  9. Banned
    May 2003
    Massachusetts
    DVD43 is teh sukc.
  10. Get DVD Decrypter. It works too and its free
    Life is like a pothole, you just have to learn to get around it.
  11. why get dvd decrypter when i can used dvd43 and recode and burn with one program, nero. Point is its fixed now. someone needs to close the thread.
  12. DVD Decrypter wont mess up your comp. Glad to hear everythings fixed.
