When i rip a dvd to vcd I'm using tmpegenc to encode, video from a vafapi-file and sound from a wav-file. But is there any way to actually "hear" the sound in tmpgenc to verify that it's in sync. now i always have to encode a small part to see if the audio is in sync.
/Mr Walker
Results 1 to 9 of 9
Nope sorry there is no way you can hear the sound in TMPGENC while encodeing
I meant before you're start the encoding. Like in preview or when you set the audio offset. But maybe thats what you ment. If it's like that I glady take some tips how to do to get audio in sync when choosing seperat video & audio source.
/Mr Walker -
encoding for a little bit and stoping it doesn't hurt anything....that's probably the easiest and safest way to make sure you're audio isn't outta sync before u spend the entire night encoding it
<font size=-1>[ This Message was edited by: poopyhead on 2001-12-13 15:27:40 ]</font> -
No real soloution as the demands of the sound and video come from north and south instructions from you CPU.
Some encodeing programs may play back or encode with audable sound, but it dos'nt meen its in sync.
Go with poopyheads's advice and do a small clip first then try it on your end format. I tend to trust what ever format I've used that works time and time again. -
But one movie that i encoded to vcd by using smartripper then dvd2avi and saved a projet-file. Did a vafapi-convertion and opened the wave and projekt-file in TMPGEnc. The audio was about 46(46550 ms) sec late. Isn't that very much? and it takes really long time to get it to sync if you should do a test-encoding over and over again before you get it right.
/Mr Walker -
hrm...a quick and easy way to get your rip 'N Sync if you know how much it is outta sync is to use the source range filter in tmpgenc
it has an audio skew option to get your audio 'N Sync (in milliseconds) -
Usally i check the audio in Virtualdub to see how much it's out of sync. Then i can use that value in TMPGEnc usually it's the same but sometimes there is a small differece between the progs.
Anyone knows a better/different way to do it??
/Mr Walker
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 05:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
