I have already updated my firmware on A08 a few times useing Hacked firmware... but I wasn't sure If it's possible to go back to pioneer's firmware.
I went to pioneer's site and downloaded the NEW bios and it wouldn't load... (because it couldn't find pioneer a08 drive...) because I have piodata firmware loaded on it.
i have R8100108.120 from pioneer's site
i have DVRFlash.exe
i have gradius v1.18 Converting Pioneer DVR-A08/108 into a true Pioneer DVR-108DX/DVR-A08DX already loaded on drive.
So can I use Gradius : R8150008.110 file plus pioneer's R8100108.120 to make Pioneer Firmware upgrade?
(it seems dvrFlash uses 2 files to flash ... and I have the one from pioneer's site ... I just wasn't sure what the other file would be and where to get it...
If you know the dvrFlash.exe COMMAND ... I wouldn't mind if you pasted it here.
(the one I used before that worked was :
c:\>dvrflash -vf X: R8150008.110 R8150108.118 )
I am not gonna proceed until I get feedback from you guys. Point me to LINK or program or files I need to convert back to Pioneer's Latest Firmware.
You might want to ask your question here:
http://club.cdfreaks.com/forumdisplay.php?f=87 -
Thanks for the link ... I went to that page yesterday looking for an answer and couldn't seem to find it ... I'm not registered there ... and ... . I was hoping someone could say ...
Go here: download this ... then at command propt ... enter this and you are set.
hopefully it's my LUCKY day!
I have recently purchased a Pioneer 108D (OEM) and flashed the drive
with F/W from Gradius v1.18 and the burner is working like a charm.
Goto gradius.com and download the file
"DVR-A08/108D drive into a true DVR-A08DX/108DX".
(support DVD-R @ 16x max and DVD-RW @ 4x max)
Another benefit of this F/W is automatic bookmark for +R blanks.
After unzipping the files (3) place them in the Folder bearing your
name in the Documents and Settings Folder.
IMPORTANT Note:
Make sure the "Intel Application Accelerator" is not installed.
Goto command prompt and "TYPE" the following command
(Note: you cannot copy and paste into Command Prompt)
C:\Documents and Settings\blinky\>dvrflash -vf X: R8150008.110 R8150108.118
NOTE: In that command statement "X" represents your burner DRIVE letter
..eg.. D or E etc. and "blinky" represents the name that appears after
"Documents and Settings" when opening Command Prompt. -
Hi rgtaa,
Curious to know why you want to flash your burner back to the original Pioneer F/W 1.18, are you having problems with the Piodata F/W you presently have installed.
Piodata is the daughter company of Pioneer and since flashing my 108D with the F/W you have installed, it has performed flawlessly.
The added feature of auto bitsetting to DVD-ROM for +R blanks is a bonus ..ie.. if you ever have to send a disc to someone with a vintage DVD player. Many older players will not play +R and may not play -R.
Those players will play DVD-ROM formatted disc's. -
no i wasn't having problems with the piodata ... but I was trying to get info on how to flash upgrade back to NEWEST Pioneer firmware ... since the Piodata firmwire version is older.
This place will prolly have the fireware you need: http://forum.rpc1.org/
Quality is my policy.
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 09:45 -
Samsung BD-P1590/BD-P1600 Foreign Firmware Flash/Region Free Issue
By 5arge in forum DVD & Blu-ray PlayersReplies: 12Last Post: 15th Apr 2012, 20:32 -
Pioneer DV-S838A firmware
By zhudinglong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 02:12 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 17:17 -
Pioneer DV-400 - avi/mpeg off flash drive?
By snowverkill in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 19:11
