Getting this error anyone know the problem have de-installed, rebooted and reupdated .net framework via windows update still get this msg
Version:SVCD2DVD 2.0 RC9 DEMO
Type: System.TypeLoadException
Source: mscorlib
Message: Could not load a type. Failed to partial bind to "DevComponents.DotNetBar.eSideBarColorScheme, DevComponents.DotNetBar, Version=4.7.0.0, Culture=neutral, PublicKeyToken=7eb7c3a35b91de04".
InnerException:
StackTrace: at System.Resources.ResourceReader.ReadResources()
at System.Resources.ResourceReader..ctor(Stream stream, Hashtable table)
at System.Resources.RuntimeResourceSet..ctor(Stream stream)
at System.Resources.ResourceManager.CreateResourceSet (Stream store)
at System.Resources.ResourceManager.InternalGetResour ceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture)
at System.Resources.ResourceManager.GetObject(String name)
at x3284ccece41ee22b.x210ff09a2516b1a7.x85601834555fb 7d5()
at x3284ccece41ee22b.x210ff09a2516b1a7..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Results 1 to 15 of 15
i was totally geeked up for this too and i having the same issue, rc7 was working fine before
Well i am away till tuesday so i can't look into this but i suspect that if you add the DotNetBar.dll to the Global Assemby Cache you will be ok.
Goto Microsoft .NET Framework 1.1 Configuration in Control Panel: Admin tools. Click on Assemby Cache and then "Add an Assembly to the Assembly Cache". Then browse to the dll in the program folder.
Let me know if this solves the problem.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
It did but an earlier version.
Yay thanks Chrissyboy worked a treat
PS kicko its under administrative tools->.net framework configuration
PS chris i'm running xp media center btw dont know about kicko -
under admin i see conponent service, event viewer, local security services, cpomuter management, services, data sources, and performance ------ Xp pro
you got .net installed?
yes i see NET if i go to add/remove programs as well as 1.1 hotfix
i when to the site and dl'd the net from the link you posted, installed, rebooted and it still get me this message
Source: mscorlib
InnerException:
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426) -
ok. You can start the .net config program using:
Code:c:\windows\Microsoft.NET\Framework\v1.1.4322\mscorcfg.msc
You are not the only one. I get the same message. I'll just uninstall and wait for a version that works.Originally Posted by kicko
dan -
i can start and open add assembly but have no idea where to look for it, and what it that dll is not there?
MAJOR update...i was able to open form the dos via the run option, then i pop in that code you dropped with the .net framework run command, then found the add assemblt and open the svcd2dvd folder to locate the dotnet(whatever) dll and Bingo bango the app opens now! -
Excellent. Sorry about this. I am away till tuesday so this workaround will have to do until i get back.
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 13:12 -
Cutterman Errors
By TwoMutts in forum EditingReplies: 2Last Post: 9th Apr 2009, 16:27 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
FAVC errors
By thai1 in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2008, 14:39 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
