Hey all,
I'm trying to transfer VHS to AVI with a VCR and a Canopus ADVC-100. Everything is hooked up (composite from VCR to ADVC, FireWire from ADVC to computer) but when I turn on the ADVC in Vegas' "Capture Video" Screen, I get the message:
"The device 'Microsoft DV camera and VCR' could not be opened.
Please make sure that it is turned on and is not being used by another application or user."
I know the ADVC-100 is supposed to be compadible with Vegas. The issue has got to be in the computer, because I've also tried to capture with Movie Maker XP (which simply freezes) and another Capture utility, which gives a similar message about the device being used by another application.
The software is recognizing that I've got Firewire hardware plugged in, but there is something amiss with the Microsoft Device that actually does the work inside. I've been scouring the net for information about "Microsoft DV and VCR" but havn't come across anything that helps.
Is there something I can download or tweak within the device manager to fix this? Is there some sort of conflict that I'm not aware of? I've closed everything running in the background. Could a messed up video driver be causing conflicts with the video capture software?
The CPU is fairly new, very fast, with hordes of memory and disk space.
Thanks in advance for any help you have to offer!
Results 1 to 1 of 1
Trouble Capturing to Sony Vegas 8
By croonprince in forum Capturing and VCRReplies: 6Last Post: 26th Jul 2011, 22:38 -
Need help: Trouble importing/capturing a "locked IFO" on DVD
By mattday79 in forum Video ConversionReplies: 3Last Post: 1st Jan 2011, 17:29 -
By mattday79 in forum Capturing and VCRReplies: 3Last Post: 1st Jan 2011, 13:41 -
ADVC-100 - capturing with macrovision disabled.
By MikeMGMVE in forum Capturing and VCRReplies: 2Last Post: 27th Dec 2009, 19:48 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 18:04
