Hi Folks,
Have not been successful in finding an easy way to make the the audio selectable without using the "info" button on my remote control.
Basically I have a video with Dolby Stereo 2.0, Dolby Surround 2.0 and Dolby 4.0 sound.
I want the user to see the following:
Play with 2.0 Dolby Stereo
Play with 2.0 Dolby Sorround
Play with 4.0 Dolby Sound
and the movie will start immediately with the selected sound (I don't need anything as complicated as an audio menu that allows you to then go to the Chapter menu etc etc etc)
I have since found an interesting guide for DVDAuthorGUI https://www.videohelp.com/~liquid217/dlfiles11/tips.pdf that I know well but my DVDLab Pro project is more or less already done and would rather get it work there before recreating the whole project with DVDAuthorGUI (Though I love that program!)
have you read
http://www.mediachance.com/dvdlab/tutorial/amanager.html ? -
Ah...thanks! I missed that actually. I was only using the online documentation that came with the app. Will read it thoroughly but it looks almost as complicated as redoing the project in DVDAuthorGUI.
There is a simpler solution if you don't need complex selection menus.
Create a simple menu with four menus items
Dolby 2.0 Stereo
Dolby 2.0 Surround
Dolby 4.0 Surround
Play Movie
Link the first item to stream one, the second to stream 2 and the third to stream three. Finally, link the Play Movie item to the movie itself.
When yoou click on an audio option it will simply return to the menu again, however when you choose play movie, it will play it with the chosen stream.
I have just tested this for someone else using DVD Lab Pro and it works quite well.Read my blog here.
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 17:45 -
DVDLab Pro Menu Text Disappearing
By C0SM0 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2009, 16:33 -
Create DVDLab DVD Scene Selection Menu
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 08:22 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 21:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
