  1. Does exist some software in which I can use software filters (for example cropping, noise reduction, ...) while I am capturig? I only need to remove (paint black) a few bottom lines which are produced by VHS tapes. The idea is to have it done all at once without reenconding the captured video. PC is fast enough (P4 3.2Ghz, 1GB memory). Thanks.
    virtualdub. in capture mode under video->filters or video->cropping or video->noise reduction.
  3. VirtualDub for mpeg2 (DVD format) capturing ? Are you sure ?
    sorry...misssed the mpeg2 part in the subject...
  5. Banned
    New York, US
    The lines on the bottom are VHS signal tracks. There should be setting on your capture card to crop the incoming video . I'm surprised you don't also have scan lines on the sides of your video (but, then, many cards don't overscan, so you won't see them).
    Depending on your capture hardware, you'll find mucho info about this at http://www.digitalfaq.com.
